[postgis-devel] Small jdbc2 patch
strk at refractions.net
Fri Jan 28 06:41:18 PST 2005
On Fri, Jan 28, 2005 at 03:04:52PM +0100, Markus Schaber wrote:
> Hi,
> I attached a small patch to jdbc2 code. It changes three minor things:
> - Add another item to the todo list.
> - A small hack to cut traling ".0" on integer coordinates on WKT output.
> As it makes things (slightly) slower, you can change Point.CUTINTS to
> false. As it is static final, the compiler optimizer eliminates the
> calls to cutint() altogether.
> - Removed some debug variables from ValueGetter.java
> BTW, as I got no feedback from users up to now: Did anyone besides strk
> and me actually test or use this code? Are we the only PostGIS JDBC
> users altogether?
Count me out, I'm not a JDBC user at all, just tried to build it ;)
BTW: would you review the README before final release ?
--strk(committed);
> Thanks,
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> Index: jdbc2/todo.txt
> RCS file: /home/cvs/postgis/postgis/jdbc2/todo.txt,v
> retrieving revision 1.1
> diff -u -r1.1 todo.txt
> --- jdbc2/todo.txt 19 Jan 2005 08:54:44 -0000 1.1
> +++ jdbc2/todo.txt 28 Jan 2005 14:00:44 -0000
> @@ -29,3 +29,6 @@
> - Possibly relicensing under LGPL
> +- Possibly adding server side code to support plJava
> + http://gborg.postgresql.org/project/pljava/projdisplay.php
> Index: jdbc2/src/org/postgis/Point.java
> RCS file: /home/cvs/postgis/postgis/jdbc2/src/org/postgis/Point.java,v
> diff -u -r1.1 Point.java
> --- jdbc2/src/org/postgis/Point.java 19 Jan 2005 08:54:44 -0000 1.1
> +++ jdbc2/src/org/postgis/Point.java 28 Jan 2005 14:00:44 -0000
> @@ -6,6 +6,8 @@
> public class Point extends Geometry {
> + public static final boolean CUTINTS=true;
> public int hashCode() {
> return super.hashCode() ^ hashCode(x) ^ hashCode(y) ^ hashCode(z) ^ hashCode(m);
> @@ -109,15 +111,26 @@
> public void innerWKT(StringBuffer sb) {
> sb.append(x);
> + if (CUTINTS) cutint(sb);
> sb.append(' ');
> sb.append(y);
> if (dimension == 3) {
> sb.append(' ');
> sb.append(z);
> if (haveMeasure) {
> sb.append(' ');
> sb.append(m);
> + private static void cutint(StringBuffer sb) {
> + int l = sb.length()-2;
> + if ((sb.charAt(l+1)=='0')&&(sb.charAt(l)=='.')) {
> + sb.setLength(l);
> Index: jdbc2/src/org/postgis/binary/ValueGetter.java
> RCS file: /home/cvs/postgis/postgis/jdbc2/src/org/postgis/binary/ValueGetter.java,v
> diff -u -r1.1 ValueGetter.java
> --- jdbc2/src/org/postgis/binary/ValueGetter.java 19 Jan 2005 08:54:44 -0000 1.1
> +++ jdbc2/src/org/postgis/binary/ValueGetter.java 28 Jan 2005 14:00:44 -0000
> @@ -83,12 +83,7 @@
> protected int getInt(int index) {
> - int hg = data.get(index + 3);
> - int high = ((int) hg << 24);
> - int hmed = ((int) data.get(index + 2) << 16);
> - int lmed = ((int) data.get(index + 1) << 8);
> - int low = (int) data.get(index);
> - return high + hmed + lmed + low;
> + return (data.get(index + 3) << 24) + (data.get(index + 2) << 16) + (data.get(index + 1) << 8) + data.get(index);
> protected long getLong(int index) {
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
