[postgis-devel] autoconf tests on head branch
strk at refractions.net
Tue Jul 5 09:25:59 PDT 2005
[ postgis-devel reintroduced in thread ]
For the list: I've been working on w32 builds with help from David
some variables have been changed, so you need ./autogen.sh
after a cvs update.
On Tue, Jul 05, 2005 at 06:17:42PM +0200, Jean David TECHER wrote:
> cvs update -C; ./autogen.sh; make install
> ....works fines :-)
Excellent. Now last thing: if you previously installed w/out --prefix
your scripts all point to $libdir (AS '$libdir/liblwgeom.1.1')
When installed w/ --prefix any change in your library won't be seen
by the actually installed scripts ...
Using the utils/postgis_proc_upgrade.pl script you should be
able to switch between installations/versions.
Would you test this ? What you can try is modifying Version.config
setting SO_MICRO_VERSION=0 and verify postgis_full_version() output.
Old installation will tell you 1.1.0CVS, new one will tell you 1.1.0.
--strk;
