[postgis-devel] postgresql sources dependency relief
alex bodnaru
alexbodn at 012.net.il
Thu Jun 2 09:56:42 PDT 2005
hi all,
to eliminate unclarities, i am posting the jdbc2 diff separated from the
overall postgis diff.
please enjoy.
any input would be most welcome.
best regards,
alex
On Thu, 2005-06-02 at 10:32 +0200, Markus Schaber wrote:
> Hi, Alex,
> alexbodn at 012.net.il wrote:
> > a few days ago you have manifested interest in the patches i have submitted
> > to postgis-cvs, to relief the build dependency on postgresql sources.
> > since i got no response from your side, i would ask you for your opinion on
> > the patches.
> > posting your opinion on the list might enlarge the testers circle before the
> > decision to apply the patches.
> I alreadyposted my comments at Tue, 31 May 2005 14:44:10 +0200, but
> here it is again:
> > Hi, Alex,
> > alex bodnaru wrote:
> >>> here is a diff you could use for jdbc2/Makefile, instead of the
> >>> previous.
> >>> i have tested it and works ok (i am using the Makefile.config
> >>> functionality).
> >>> i would be grateful if you could test with it for the special cases you
> >>> know about.
> > In my tests, it built the jar files and ran the tests without having a
> > ../Makefile.config.
> > Great work.
> > As this patch seems to depend on those for the non-jdbc Makefiles, I
> > will not commit it now, but I think it should be committed with the others.
> >>> p.s. the moment we merge those changes, i can already send a new and
> >>> slim debian package for postgis-1.1.
> >>> current packages are at http://packages.qa.debian.org/p/postgis.html.
> > Great!
> > Markus
> HTH,
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050602/176783e2/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050602/176783e2/attachment-0001.bin>
