[postgis-devel] relief of dependency on postgresql sources
strk at refractions.net
Sat Jun 4 03:17:44 PDT 2005
Alex, thank you for your work. I've committed your patch to easy
further testing (head branch).
The jdbc2/Makefile separated one is not there yet, Markus, could you
apply it yourself ?
I think next step should be having path names match the 1.0.1 layout
and to test with different pgsql versions/configurations. I have
no default installation of pgsql, if anyone does tests against
them would be highly appreciated.
--strk;
On Tue, May 31, 2005 at 02:44:10PM +0200, Markus Schaber wrote:
> Hi, Alex,
> alex bodnaru wrote:
> > here is a diff you could use for jdbc2/Makefile, instead of the
> > previous.
> > i have tested it and works ok (i am using the Makefile.config
> > functionality).
> > i would be grateful if you could test with it for the special cases you
> > know about.
> In my tests, it built the jar files and ran the tests without having a
> ../Makefile.config.
> Great work.
> As this patch seems to depend on those for the non-jdbc Makefiles, I
> will not commit it now, but I think it should be committed with the others.
> > p.s. the moment we merge those changes, i can already send a new and
> > slim debian package for postgis-1.1.
> > current packages are at http://packages.qa.debian.org/p/postgis.html.
> Great!
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
