[postgis-devel] invalid memory alloc request size
Markus Schaber
schabi at logix-tt.com
Thu Jun 9 10:17:38 PDT 2005
Hi, Strk,
strk at refractions.net wrote:
> Does
> SELECT 'GEOMETRYCOLLECTION EMPTY'::geometry;
> give you the same problem ? (box3d should be computed anyway)
gisblau=# select 'GEOMETRYCOLLECTION EMPTY'::geometry;
geometry
010700000000000000
(1 row)
gisblau=# select multi('GEOMETRYCOLLECTION EMPTY'::geometry);
ERROR: invalid memory alloc request size 0
gisblau=# select isvalid('GEOMETRYCOLLECTION EMPTY'::geometry);
Seems not the case, I'll see tomorrow whether I can track it down more
precisely.
Thanks,
Schabi
