[postgis-devel] GeomUnion Performance Info
strk at refractions.net
Thu Jun 23 02:54:23 PDT 2005
On Wed, Jun 22, 2005 at 09:52:17PM -0400, Bill Binko wrote:
> strk,
> I'm going to have to rerun all of the performance graphs if it's going to
> be a reasonable comparision. The reason is that the database has simply
> not stayed static since I ran those. I have added columns, indexes, etc.
> and it simply wouldn't be meaningful.
> So, I will get your short-circuit code in there, and run the following
> tests (with the same data and load):
> 1) Random Sort (clustered)
> 2) GiST Clustered
> 3) BTree clustered (a bit hard, but I can do it)
> And I'll run them both with and without the short-circuit code. Is there
> a runtime switch? If not, I'll recompile gdal with and without (I
> shouldn't have to rebuild postgis right?).
You only need rebuild GEOS, no runtime switch, just a define
#define SHORTCIRCUIT_PREDICATES 1
on top of source/geom/Geometry.cpp
Also, on line 611 uncomment the
'//cerr<<"SHORTCIRCUITED-UNION engaged"<<endl;'
line, so you can see how many cases of disjoint bboxes happen with
btree or GiST and report that as well.
> It will take at least tomorrow to do that. However, I'll aim for being
> complete before the weekend in case there's development to be done then.
Thank you !
--strk;
