[postgis-devel] Re: Fixing r-tree semantics
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Fri Jun 24 00:04:47 PDT 2005
Hi Tom,
> What needs more discussion is that it seems to me to make sense to extend
the standard
> opclasses to handle the four Y-direction operators comparable to the
X-direction
> operators that are already there, that is "above", "below", "overabove",
and
> "overbelow".
As part of PostGIS (http://postgis.refractions.net), I submitted a patch a
while back to add additional Y-direction operators to the code which is a
slightly modified version of rtree_gist (and yes, the PostGIS implementation
will suffer from the same issues you've found with the existing R-tree
implementations).
The operators I went for were as follows:
A &<| B - true if A's bounding box overlaps or is below B's bounding
box
A |&> B - true if B's bounding box overlaps or is above B's bounding
box
A <<| B - true if A's bounding box is strictly below B's bounding
box
A |>> B - true if A's bounding box is strictly above B's bounding
box
Since the rtree_gist implementation and operators were 2D, my thoughts were
to use another op-class only if the indexing were upgraded to 3D. So with
this in mind, I created the following new GiST strategies:
#define RTOverBelowStrategyNumber 9
#define RTBelowStrategyNumber 10
#define RTAboveStrategyNumber 11
#define RTOverAboveStrategyNumber 12
This is basically what you are suggesting but with a | instead of a ^ in the
operator name (my original choice was to try and use } to indicate the
positive sense of the Y-axis but this was not accepted as a valid operator
character which is why I changed to |).
It would be harder for us to change these operators since they already
exist, but then again it would be useful from a maintenance point of view to
keep the strategy numbers and operators the same across both
implementations. Of course strategy numbers are just used internally so
these aren't such a big issue - it's more the choice of operators that would
be useful to agree on.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
