[postgis-devel] chunked GeomUnion commit
strk at refractions.net
Tue Jun 28 04:43:51 PDT 2005
Bill, sorry but there has been many changes recently in ALL
repositories...
I will now freeze GeomUnion related works in all of them
to take allow you running tests.
Briefly:
GEOS improvements have been ported from JTS
and customly made for Buffer op. Generally
speaking HEAD branch should be faster then
2.1-branch. 2.1-branch should be *faster*
then 2.1.2, if you really see other results
we have a problem!
PostGIS GeomUnion function now uses 'chunked'
buffering of input. Size of chunks is defined
by number of vertex in input and you can
set it using a define at top of lwgeom_geos.c.
This is both in HEAD and 1.0-branch.
In both cases using buffer(collect(p),0) would
use a single BIG chunk thus giving better results
if available memory is enough.
Buffer(collect(p),0) would work on all postgis
*releases*.
When online you can talk to me on freenode irc network.
--strk;
