[postgis-devel] GEOS and PostGIS release candidates
strk at refractions.net
Tue Jun 28 13:49:18 PDT 2005
PostGIS and GEOS repository have been tagged to act
as release candidates for 1.0.2 and 2.1.3 respectively
GEOS: rel-2-1-3-rc1
POSTGIS: pre_1_0_2_unionTest
All tests are welcome, Changes (in order to know what to test):
Postgis:
- Fault tolerant btree ops
- Memory Leak fix in pg_error
- Rtree index fix. See:
http://archives.postgresql.org/pgsql-hackers/2005-06/msg01108.php
- Chunked GeomUnion implementation (much faster)
- Support for postgresql 8.1
- Cleaner build scripts: avoided mix of CFLAGS and CXXFLAGS
GEOS:
- win32/mingw build support
- Segfault fix in LinearRing and LineString constructors
- Segfault fix in Polygonizer
- XMLTester installed by default
- XMLTester code cleanup
- Fixed handling of collection input in GeometryFactory::buildGeometry
- Added shortcircuit test for Union operation
- Reduced useless Coordinate copies in CGAlgorithms::isPointInRing()
- Performance improvements in CGAlgorithms::isOnLine()
- Other minor performance improvements
- New Node::isIncidentEdgeInResult() method
- OverlayOp's PointBuilder performance improvement by reduction
of LineIntersector calls.
- Optimizations in Buffer operation
- Sever BUGFIX in DepthSegmentLT as suggested by Graeme Hiebert
--strk;
