[postgis-devel] WKB Problems on 64-Bit Linux
clozano at quavantis.com
Mon Mar 14 04:51:27 PST 2005
I've checked out the last version from the CVS... clean compile... WKB
problems no longer occur on AMD64! Everything works perfectly.
Thanks guys!
Salutacions - Un Saludo - Regards,
Carlos Lozano Diez
Quavantis - mWorld Company
Mobile & Wireless Solutions
Email: clozano at quavantis.com
Phone: +34 93 4515125
Mobile: +34 678 746275
Web: http://www.quavantis.com
Office (Spain):
Villarroel 70, 2º 1º
08011 Barcelona
Office (UK):
16-19 Southampton Place
London, WC2A 2AJ
postgis-devel-bounces at postgis.refractions.net wrote on 10/03/2005
20:15:09:
> The bug is fixed for what I can tell.
> Our "int4" typedef is 8bytes in size :( and this was confusing
> the code. I didn't force int4 to really be 4 bytes ( w/out autoconf
> I wouldn't know how), but making sure int4 vars intended to be
> written-to from the byte stream readers are initalized to zero
> fixes the bug.
> Can all reporting guys check this out ?
> It's in current CVS, or - if you feel - this is enough:
> around line 689 in lwgeom/lwgparse.c
> - int4 ret;
> + int4 ret=0;
> --strk;
> On Thu, Mar 10, 2005 at 10:19:52AM -0000, Mark Cave-Ayland wrote:
> > > -----Original Message-----
> > > From: postgis-devel-bounces at postgis.refractions.net
> > > [mailto:postgis-devel-bounces at postgis.refractions.net] On
> > > Behalf Of strk at refractions.net
> > > Sent: 08 March 2005 18:22
> > > To: PostGIS Development Discussion
> > > Subject: Re: [postgis-devel] WKB Problems on 64-Bit Linux
> > (cut)
> > > Maybe I have completely different problems here. Sorry, but I
> > > just started building code on the AMD64...
> > > BTW, were all 0.x working fine ? Could you check 0.9.2 ?
> > > If it is an *old* bug/missupport we might take care of it for
> > > 1.0.1 ...
> > > --strk;
> > Hi strk,
> > I've loaded in several very large geometry tables into a database on
AMD64
> > under PostGIS 0.9.1 without any problems, so it's a 1.0.0 issue.
> > Kind regards,
> > Mark.
> > WebBased Ltd
> > South West Technology Centre
> > Tamar Science Park
> > Plymouth
> > PL6 8BT
> > T: +44 (0)1752 791021
> > F: +44 (0)1752 791023
> > W: http://www.webbased.co.uk
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050314/e1821e63/attachment.html>
