[postgis-devel] Re: PostGIS / SHP loader: inner rings discarded
Sandro Santilli
strk at refractions.net
Mon Mar 14 13:47:54 PST 2005
Thank you LASZLO, committed.
--strk;
On Mon, Mar 14, 2005 at 10:06:07PM +0100, LASZLO Istvan wrote:
> Dear Developers,
> It seems that I have found a small bug in shp2pgsql.c. It causes
> that only the first inner rings of polygons are loaded. (Sorry
> if already known.)
> As far as I can see, changing of 'break;' to 'continue;' in line
> 982 of shp2pgsql.c (both RC3 and current CVS version) solves the
> problem.
> if ( outer )
> outer->linked++;
> while(outer->next) outer = outer->next;
> outer->next = inner;
> break; // should be: continue;
> If an inner ring is found within an outer one, 'break;' exits
> from the whole loop enumerating inner rings. However,
> 'continue;' skips only the reporting of an 'orphan hole', which
> is probably the intended behaviour.
> I have tested it on several complex cases, the result looks much
> better. :-)
> Best regards,
> Istvan
> Istvan LASZLO
> Institute of Geodesy, Cartography and Remote Sensing (FOMI)
> Budapest, Hungary
