[postgis-devel] Backend crash with RC3 and RC4
strk at refractions.net strk at refractions.net
Wed Mar 23 03:21:01 PST 2005
Postgresql version ?
Architecture ?
A test file with load/vacuum/select/bang ?
--strk;
On Wed, Mar 23, 2005 at 11:05:04AM -0000, Martin Daly wrote:
> All,
> We've been testing RC4, and found that a certain sequence of events
> causes a backend crash.  We've checked RC3 and RC2, and RC3 also has the
> crash, whereas RC2 does not.  The sequence is as follows:
> 1. Load data file into SIS (in this case standard MapInfo sample
> WORLD.MIF)
> 2. Use SIS PostGIS exporter to write the data to a new PostGIS table
> This step creates a spatial index on the geometry column, and does a
> vacuum analyze on the table.
> 3. Use the SIS PostGIS Wizard to connect to the new table
> 4. Bang:
> "server closed the connection unexpectedly
> 	This probably means the server terminated abnormally
> 	before or while processing the request."
> The part of 3. that is causing the crash is this request (SIS wants a
> default extents of the table for the initial view):
> DECLARE C7 NO SCROLL CURSOR FOR select estimated_extent('public',
> 'world', 'geometry')
> If we do 1. then 2. then use psql to run this query instead of SIS, then
> we still get the crash.
> Bizarrely, after the backend has restarted, the query works fine, even
> in the same SIS session.
> Any ideas?
> Martin
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
