[postgis-devel] Ebuilds Gentoo for Geos 2.1.1 an dPostGIS 1.00Rc5 available
TECHER Jean David
davidtecher at yahoo.fr
Sat Mar 26 07:31:32 PST 2005
Hi
We tested the ebuild for Geos 2.1.1 and PostGIS 1.0.0Rc5 at work ...All works fine..
If U want to test the PosTGIS ebuild and Geos ebuild go to:
http://www.01map.net/gentoo
++++ For PostGIS+++++++++++++++++++++++
Download all files in dev-db/postgis (recursively)
++++For Geos+++++++++++++++++++++
Download all files in sci-lib/geos
++For both (geos+postgis):+++++++++++++++++
Do the following commands as root:
mkdir /usr/local/portage.01map
echo PORTDIR _OVERLAY=\"usr/local/portage.01map\" >> /etc/make.conf
then U 'll be able to install our ebuilds by typing:
ACCEPT_KEYWORDS="~x86" emerge -v postgis
for recommended support of geos and proj prefer this :
USE="geos proj" ACCEPT_KEYWORDS="~x86" emerge -v postgis
(you could also use this command :
echo "dev-db/postgis ~x86" >> /etc/portage/package.keywords ,
then use
emerge -v postgis)
and then ...Enjoy!!!!
TECHER Jean David
Responsable Informatique 01MAP
e-mail: davidtecher at yahoo.fr
Bureau: 04 67 45 60 27
Portable: 06 85 37 36 75
site perso : http://techer.pascal.free.fr/postgis/
site pro: http://www.01map.com/download/
K-S:"The greatest trick the devil pulled off was convincing people he didn't exist"
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20050326/41fd83ef/attachment.html>
