[postgis-devel] RE: [postgis-users] pgsql2shp changing case of fieldnames
Obe, Regina DND\MIS robe.dnd at cityofboston.gov
Mon May 16 07:08:47 PDT 2005
strk,
I tried the same test without the k option and it produces 2 fields in the
dbase table called "LABEL".
So it appears to be an issue in both cases.
Actually in the non-k based situation - at least in windows, it's a more
serious issue because the
		 * make sure the fields all have unique names,
		 * 10-digit limit on dbf names...
rarely kicks in because it is always comparing the Pg field name with the
uppered field name? So you end up
With situations like
If you have two field names
testing123456, testing12345
They both get output as identical
"TESTING123"
Because the compare is always comparing the testing123 against "TESTING123"
In the non-k situation.
I think if we just change this section to a case-insensitive match, then
that will fix everything.
You want me to take a shot at fixing this?  Maybe just double check on your
system to make sure my above assumption is correct.
-----Original Message-----
From: strk at refractions.net [mailto:strk at refractions.net]
Sent: Friday, May 13, 2005 10:51 AM
To: Obe, Regina DNDMIS
Cc: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-users] pgsql2shp changing case of fieldnames
On Fri, May 13, 2005 at 10:45:05AM -0400, Obe, Regina     DNDMIS wrote:
> Hi strk,
> It is Regina.  I guess we should check or give a warning.  I tried a
> test with outputing a table with one field named label and another
> "LABEL" and then opened it in Arc Explorer.  It opens in Arc Explorer
> fine, but when you use the information tool it only shows one of the
> "label" fields and kicks the other one out.
> I tried a DBF ODBC driver and got similar behavior.
So, are you suggesting pgsql2shp issueing a warning when caseless equality
of 2 fields is detected with -k ?
(it renames duplicated field names w/out -k)
--strk;
> Thanks,
> Regina
> From: 'strk at refractions.net' [mailto:strk at refractions.net]
> Sent: Friday, May 13, 2005 10:09 AM
> Thanks Obe (or Regina?).
> I've applied your patch, but I'm not sure about something: would a DBF
> be legal if it contains attributes like 'LABEL' and 'label' in the
> same file ? This would be a valid postgresql table, but is this true
> for .dbf ?
> In case it isn't we should do a case-insensitive match where
> we check this (around line 2650). I left a TODO there:
>       * TODO: check out if should be case-insensitive
>       * here since we might be running in -k mode
> --strk;
> On Fri, May 13, 2005 at 08:41:54AM -0400, Obe, Regina     DNDMIS wrote:
> > I was working off of the cvs hourly build snapshot from the postgis
> > site. Unfortunately I'm behind a firewall so don't think I can hit a
cvs.
> > I made a diff patch.  Attached is the file.  I hope I did it right.
> > Thanks,
> > Regina
> > Sent: Friday, May 13, 2005 3:26 AM
> > On Thu, May 12, 2005 at 08:27:57AM -0400, Obe, Regina     DNDMIS wrote:
> > > I've made the change in my copy and it seems to work okay so far.
> > > I'm
> > > going to test it a little more.  So I guess I just need to know how to
> > > send you the patch.
> > Are you working on a CVS snapshot ?
> > If so use cvs diff and send me the output (should be small). If you
> > have problems with that just send me the whole pgsql2shp.c file and
> > I'll check the changes myself. Thanks.
> > --strk;
> > > Thanks,
> > > Regina
> > > Sent: Tuesday, May 10, 2005 2:42 PM
> > > Cc: 'PostGIS Users Discussion'
> > > I've added the request in the HEAD branch TODO list.
> > > If you will do it yourself sooner then us
> > > we'll accept patches. Let me know if you plan to do it and feel
> > > free to ask any info you might need for that.
> > > --strk;
> > > On Mon, May 09, 2005 at 04:02:46PM -0400, Obe, Regina     DNDMIS
wrote:
> > > > The old one I had was dated sometime in 2003 and was compiled
> > > > under cygwin, but it still seemed to work when I upgraded to 8.0.
> > > > I think a -k switch would be best.
> > > > The older version preserved the case that was in postgres so for
> > > > situations where we needed UPPERCASE (standard shp behavior) we
> > > > had to create views that had the fields upper cased and dumped
> > > > those out; so this new version irradicates that need.  There are
> > > > some situations where it is convenient to keep the same case as
> > > > postgres - e.g. it makes it easier to swap out a postgis layer
> > > > with a shape layer where postgis is not feasible for a particular
> > > > environment.  I'm assuming mapserver is still case sensitive with
> > > > field names in templates.
> > > > Sent: Monday, May 09, 2005 11:26 AM
> > > > To: 'PostGIS Users Discussion'
> > > > fieldnames
> > > > On Mon, May 09, 2005 at 10:18:52AM -0400, Obe, Regina     DNDMIS
> wrote:
> > > > > I noticed the 3/31/05 build of pgsql2shp I have now
> > > > > automatically
> > > > > forces the output field names to upper case which normally would
> > > > > be a good thing. Unfortunately I've got some old mapserver maps
> > > > > that rely on the field names in the dbf being in lowercase.  Is
> > > > > there anyway to reverse this behavior e.g. with a switch or
> > > > > something of that sort so that I don't have to revert back to the
> > > > > older version of pgsql2shp?
> > > > > Thanks,
> > > > > Regina
> > > > Which version of pgsql2shp doesn't do that ?
> > > > I guess we can revert the change back ... or add a -k switch to
> > > > it as well.
> > > > Does anyone see a problem with this ?
> > > > --strk;
> > > > _______________________________________________
> > > > postgis-users mailing list postgis-users at postgis.refractions.net
> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
