[postgis-devel] autoconfiguration for version 1.1.0CVS
alexbodn at 012.net.il
Tue May 17 06:28:59 PDT 2005
hello friends,
though the autoconfiguration of postgis should use only the publicly available postgresql
information, i think we went too far with dropping usage of Makefile.shlib.
this file is a collection of information needed to make a shared library in the postgresql
environment, as is stated in it's header.
although i agree it could be splitted in small files, each for a specific architecture, and
included with the postgresql api, this information should be undoubtely used in the
process of building postgis, which is a shlib itself.
please also note, that newer postgresql is only adding new architectures to this file, but
it doesn't make other significant changes.
at the moment, the linux postgis library is lacking the SONAME, and this is the situation
with other unices, too.
i would kindly ask you to reinclude Makefile.shlib dependency in postgresql, and in the
most extreme situation, please include a separate Makefile.shlib for each supported
postgresql branch.
best regards,
alex
