[postgis-devel] postgresql sources dependency relieved
strk at refractions.net strk at refractions.net
Tue May 24 00:19:00 PDT 2005
Thank you alex. I've applied your patch - manually handling
rejected part for printwkb.c.
This is an error I get running ./configure && make:
make[1]: Circular all-shared-lib <- liblwgeom.so.1.1 dependency dropped.
measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o   wktunparse.o lwgparse.o wktparse.tab.o lex.yy.o vsprintf.o liblwgeom.o lwgeom_pg.o lwgeom_debug.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_nojts.o lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o stringBuffer.o lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_svg.o lwgeom_gml.o lwgeom_triggers.o lwgeom_dump.o  -shared  -L/usr/bin/../lib -lproj -o liblwgeom.so.1.1
make[1]: measures.o: Command not found
make[1]: *** [liblwgeom.so.1.1] Error 127
--strk;
On Tue, May 24, 2005 at 05:19:49AM +0300, alex bodnaru wrote:
> hi,
> the diff is attached.
> i have made it against not the very latest cvs snapshot.
> alex
> On Mon, 2005-05-23 at 14:25 +0300, alexbodn at 012.net.il wrote:
> > hi strk, listers,
> > as promised, i am happy to announce that i have totally
> > relieved the postgis making dependency on postgresql
> > sources.
> > now are needed only current headers, and Makefile.shlib,
> > preferrably from latest postgresql.
> > i have successfully tested postgis 1.1.0cvs with postgresql
> > 7.4.x and Makefile.shlib from postgresql 8.0.x. or 7.4.x.
> > the diffs might be isolated by tonight (gmt+2), and i will try them
> > on older postgis, too.
> > alex
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
