[postgis-devel] Transform() PROJ4 cache patch
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Wed Nov 2 01:51:12 PST 2005
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 02 November 2005 07:43
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] Transform() PROJ4 cache patch
> Mark, the new version builds fine on 7.2.1
> Before continuing with the test would you please take the
> transform_geom() function back ?
> It would break back-compatibility if we remove it.
> Also, please work against the head branch.
> Later.
> --strk;
Hi strk,
Thanks for testing again. Do you mean 1.1.0CVS HEAD or the pgis_1_0 branch?
It would be really nice to get this in 1.0.x if we can persuade users to
upgrade their SQL scripts :)
Also, do you think it's really worth keeping transform_geom()? I only
realised it was there while writing this patch since it is an internal API
and not documented anywhere. Perhaps a quick poll on -users?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
