[postgis-devel] Memory alignment issues (was: crash (somehow)resolved)
strk at refractions.net strk at refractions.net
Wed Nov 16 01:24:50 PST 2005
On Wed, Nov 16, 2005 at 09:09:19AM -0000, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: postgis-devel-bounces at postgis.refractions.net
> > [mailto:postgis-devel-bounces at postgis.refractions.net] On
> > Behalf Of Michael Fuhr
> > Sent: 15 November 2005 20:21
> > To: postgis-devel at postgis.refractions.net
> > Subject: Re: [postgis-devel] Memory alignment issues (was:
> (cut)
> > Regression tests passed for both the 1.0 branch and HEAD with
> > the exception of the differences below.  The first is due to
> > the output being "Infinity" instead of "inf"; the second
> > appears to be due to slight differences in floating-point
> > calculations; the third is a NOTICE message that isn't in the
> > expected output.
> Hi Michael,
> Thanks for doing this! Is this something that you can easily re-run? I'm
> getting to the point where I'm nearly ready to commit my transform() caching
> patch to CVS HEAD and due to the nature of the code, it is likely I may have
> made some alighment errors somewhere :)
Ehm... unfortunately there are no transform() calls in the
regression test. The whole regression tests need a lift actually.
--strk;
