[postgis-devel] Re: PostgreSQL HEAD array changes
Michael Fuhr
mike at fuhr.org
Fri Nov 18 17:40:21 PST 2005
On Thu, Nov 17, 2005 at 05:55:23PM -0700, Michael Fuhr wrote:
> A change was recently committed to PostgreSQL HEAD (8.2devel) that
> affects arrays; among other things it removes the ARR_OVERHEAD macro
> that PostGIS uses.
More on this: to run under the latest PostgreSQL HEAD (8.2devel),
PostGIS needs to do a couple of things (conditionally starting with
PostgreSQL 8.2):
* Use ARR_OVERHEAD_NONULLS instead of ARR_OVERHEAD. Otherwise
the compiler raises an "implicit declaration of function `ARR_OVERHEAD'"
warning and the runtime linker fails to load liblwgeom.so with
an error like "symbol ARR_OVERHEAD: referenced symbol not found."
* Set an array structure's dataoffset field to 0 to indicate
that the array doesn't contain NULLs. Otherwise a segfault
might result.
I've attached a patch to PostGIS HEAD that shows these changes; the
same changes should probably be applied to the 1.0 branch. Defining
ARR_OVERHEAD(x) as ARR_OVERHEAD_NONULLS(x) might not be the best
decision, but at least the patch shows what needs to change to get
PostGIS working under PostgreSQL HEAD. I leave it to better
programmers than myself to decide what's best :-)
The version-determining code in Makefile.config.in could probably
use some restructuring -- it keeps creeping to the right with every
new version of PostgreSQL.
Michael Fuhr
Index: Makefile.config.in
RCS file: /home/cvs/postgis/postgis/Makefile.config.in,v
retrieving revision 1.21
diff -c -r1.21 Makefile.config.in
*** Makefile.config.in 1 Nov 2005 17:11:20 -0000 1.21
--- Makefile.config.in 19 Nov 2005 01:21:14 -0000
*** 165,171 ****
ifneq ($(findstring 8.0,$(VERSION)),)
USE_VERSION=80
else
! USE_VERSION=81
endif
endif
endif
--- 165,175 ----
USE_VERSION=80
else
! ifneq ($(findstring 8.1,$(VERSION)),)
! USE_VERSION=81
! else
! USE_VERSION=82
! endif
endif
endif
endif
Index: lwgeom/lwgeom_functions_basic.c
RCS file: /home/cvs/postgis/postgis/lwgeom/lwgeom_functions_basic.c,v
retrieving revision 1.125
diff -c -r1.125 lwgeom_functions_basic.c
*** lwgeom/lwgeom_functions_basic.c 18 Nov 2005 10:16:21 -0000 1.125
--- lwgeom/lwgeom_functions_basic.c 19 Nov 2005 01:21:15 -0000
*** 15,20 ****
--- 15,24 ----
#include "profile.h"
#include "wktparse.h"
+ #if USE_VERSION >= 82
+ # define ARR_OVERHEAD(x) ARR_OVERHEAD_NONULLS(x)
+ #endif
//#define PGIS_DEBUG 1
Datum LWGEOM_mem_size(PG_FUNCTION_ARGS);
*** 2119,2124 ****
--- 2123,2131 ----
#if USE_VERSION > 72
result->elemtype = oid;
#endif
+ result->dataoffset = 0;
+ #endif
memcpy(ARR_DIMS(result), &nelems, sizeof(int));
memcpy(ARR_LBOUND(result), &lbs, sizeof(int));
memcpy(ARR_DATA_PTR(result), geom, geom->size);
