[postgis-devel] more fun on Ultrasparc, unfortunately...
Alex Mayrhofer axelm-postgis at nona.net
Wed Nov 30 08:21:49 PST 2005
strk at refractions.net wrote:
> Thank you.
> Note that you don't need to provide separate scripts for HEAD,
> two of the three you produce for 1.0 are enough.
Here we are.
In case you need a disclaimer to include them: I declare that you may use
those files however you see fit.
cheers
alex
0|EMPTY
1|SRID=32633;POINT(574600 5316780)
2|SRID=32633;POINT(574600 5316780)
3|SRID=32633;POINT(574600 5316780)
4|SRID=32633;LINESTRING(574600 5316780,573140 5427940)
5|SRID=32633;LINESTRING(574600 5316780,573140 5427940)
6|16.00000000|48.00000000
ERROR:  Input geometry has unknown (-1) SRID
8|SRID=4326;POINT(0 0)
#!/bin/sh
if [ -z "$TMPDIR" ]; then
	TMPDIR=/tmp
fi
OUTFILE="${TMPDIR}/regress_proj_out$$"
echo "Running PROJ Regression Test..."
echo "Output file is: '${OUTFILE}'"
echo
echo "       expected:'<'     obtained:'>'"
echo
DB=postgis_reg
createdb $DB > /dev/null
createlang plpgsql $DB > /dev/null
psql -f ../lwpostgis.sql $DB > /dev/null 2>&1
psql -tA < regress_proj.sql $DB 2>&1 | grep -v INSERT > "${OUTFILE}"
diff regress_proj_expected "${OUTFILE}"
sleep 1
dropdb $DB > /dev/null
-- some transform() regression
-- prime spatial_ref_sys table with two projections
--- EPSG 32633 : WGS 84 / UTM zone 33N
INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (32633,'EPSG',32633,'PROJCS["WGS 84 / UTM zone 33N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",15],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32633"]]','+proj=utm +zone=33 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ');
--- EPSG 4326 : WGS 84
INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (4326,'EPSG',4326,'GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]','+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ');
--- test #0: NULL values
SELECT 0,coalesce(AsText(transform(NULL, 32633)),'EMPTY');
--- test #1: a simple projection
SELECT 1,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;POINT(16 48)'),32633),10));
--- test #2: same in 3D
SELECT 2,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;POINT(16 48 171)'),32633),10));
--- test #3: same in 4D
SELECT 3,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;POINT(16 48 171 -500)'),32633),10));
--- test #4: LINESTRING projection, 2 points
SELECT 4,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;LINESTRING(16 48, 16 49)'),32633),10));
--- test #5: LINESTRING projection, 2 points, 4D
SELECT 5,AsEWKT(SnapToGrid(transform(GeomFromEWKT('SRID=4326;LINESTRING(16 48 0 0, 16 49 0 0)'),32633),10));
--- test #6: re-projecting a projected value
SELECT 6,round(X(transform(transform(GeomFromEWKT('SRID=4326;POINT(16 48)'),32633), 4326))::numeric,8),round(Y(transform(transform(GeomFromEWKT('SRID=4326;POINT(16 48)'),32633), 4326))::numeric,8);
--- test #7: Should yield an error since input SRID is unknown
SELECT transform(GeomFromEWKT('SRID=-1;POINT(0 0)'),4326);
--- test #8: Transforming to same SRID
SELECT 8,AsEWKT(transform(GeomFromEWKT('SRID=4326;POINT(0 0)'),4326));
