[postgis-devel] Sparc 64bit problems
Stephen Campbell
Stephen at me.massey.landcare.cri.nz
Fri Oct 14 21:53:28 PDT 2005
Hi strk,
[] One of your query doesn't involve GEOS, so I'd drop geos
[] as the first thing. This is the AsText(GeometryN()) query.
[] Would you try removing the AsText part so we're left
[] with the GeometryN and canonical output functions only ?
I noticed when I was running to do your queries that the behaviour is changing with a fresh psql client between the initial query and subsequent ones, mainly in causing the memory runaway but also note the very last one (which was in fact the very first run).
Note that this is on a running postgresql engine with the test db already in place. It had, I think, last been used running an explain analyse verbose version of the OGC queries.
(Also GEOS seemed to run though its /source/test/'s ok.)
Cheers, Stephen.
Welcome to psql 8.0.4, the PostgreSQL interactive terminal.
spdb=# SELECT GeometryN(centerlines, 2) FROM divided_routes WHERE name = 'Route 75';
geometryn
0020000002000048E700000000
(1 row)
ERROR: invalid memory alloc request size 1073741824
spdb=# \q
-- the answer doesn't tally with the sparcv7 (32bit) one which
-- is longer so I guess the AsText is correct, and the problem
-- with it is just that its applied after the GeometryN and
-- whatever its leaving messed up?
spdb=# SELECT ExteriorRing(shore) FROM lakes WHERE name = 'Blue Lake';
exteriorring
(1 row)
spdb=# \q
spdb=# SELECT AsText(Difference(named_places.boundary, forests.boundary)) FROM named_places, forests WHERE named_places.name = 'Ashton' AND forests.name = 'Green Forest';
spdb=# \q
spdb=# SELECT Difference(named_places.boundary, forests.boundary) FROM named_places, forests WHERE named_places.name = 'Ashton' AND forests.name = 'Green Forest';
difference
0020000003000048E700000000
(1 row)
spdb=# \q
spc=# SELECT GeometryN(centerlines, 2) FROM divided_routes;
geometryn
(1 row)
spdb=# \q
spdb=# SELECT AsText(GeometryN(centerlines, 2))
spdb-# FROM divided_routes
spdb-# WHERE name = 'Route 75';
FROM divided_routes
astext
LINESTRING EMPTY
(1 row)
FROM divided_routes
astext
LINESTRING(16 0,16 23)
(1 row)
FROM divided_routes
astext
(1 row)
