[postgis-devel] added Azimuth(geometry, geometry)
strk at refractions.net
Tue Oct 25 07:24:11 PDT 2005
I've added a C port of Hartmut's plpsgql
Azimuth(point, point) function in the head branch.
Contrary to Hartmut version this one:
- doesn't attempt at reprojecting input
- returns radians
- checks for SRID match
--strk;
On Thu, Sep 15, 2005 at 06:27:49PM +0900, Hartmut Tschauner wrote:
> Hi Ahmet,
> In an earlier message that didn't arrive as part of this thread and with its
> body scrapped, I posted a function (see below) that will calculate azimuth
> between two points. You would pass the start and end points to get the
> direction of a line.
> Cheers,
> Hartmut
> Hartmut Tschauner
> Department of Archaeology
> Seoul National University
> Gwanak-Gu Sillim 9-dong San 56-1
> Seoul, 151-742
> Korea
> ph. +82 (2) 880-9260
> CREATE OR REPLACE FUNCTION public.azimuth(geometry, geometry)
> RETURNS float8 AS
> DECLARE
> geom1 ALIAS FOR $1;
> geom2 ALIAS FOR $2;
> geom2trans geometry;
> BEGIN
> IF geom1 IS NULL OR geom2 IS NULL THEN
> RETURN NULL;
> ELSE
> IF isempty(geom1) OR isempty(geom2) OR geometrytype(geom1) !=
> \'POINT\' OR geometrytype(geom2) != \'POINT\' THEN
> RETURN NULL;
> END IF;
> END IF;
> IF srid(geom1) != -1 AND srid(geom2) != srid(geom1) THEN
> geom2trans := transform(geom2, srid(geom1));
> ELSE
> geom2trans := geom2;
> END IF;
> IF x(geom1) = x(geom2trans) AND y(geom1) < y(geom2trans) THEN
> RETURN 0;
> ELSIF x(geom1) = x(geom2trans) AND y(geom1) > y(geom2trans) THEN
> RETURN 180;
> ELSIF y(geom1) = y(geom2trans) AND x(geom1) < x(geom2trans) THEN
> RETURN 90;
> ELSIF y(geom1) = y(geom2trans) AND x(geom1) > x(geom2trans) THEN
> RETURN 270;
> ELSIF x(geom1) < x(geom2trans) AND y(geom1) < y(geom2trans) THEN
> RETURN degrees(atan(abs(x(geom1) - x(geom2trans)) / abs(y(geom1) -
> y(geom2trans))));
> ELSIF x(geom1) < x(geom2trans) AND y(geom1) > y(geom2trans) THEN
> RETURN degrees(atan(abs(y(geom1) - y(geom2trans)) / abs(x(geom1) -
> x(geom2trans)))) + 90;
> ELSIF x(geom1) > x(geom2trans) AND y(geom1) > y(geom2trans) THEN
> y(geom2trans)))) + 180;
> ELSIF x(geom1) > x(geom2trans) AND y(geom1) < y(geom2trans) THEN
> x(geom2trans)))) + 270;
> ELSE
> RETURN 0;
> END IF;
> END;
> LANGUAGE 'plpgsql' VOLATILE;
> postgis-users mailing list
