[postgis-devel] PostGis Installation Problems
strk at refractions.net
Tue Apr 4 00:50:23 PDT 2006
It seems your compiler is not finding proj4 header.
If this is the case you should see another warning or error
about not finding projects.h.
--strk;
On Mon, Apr 03, 2006 at 09:40:22PM +0200, Albert Leibbrandt wrote:
> Hi
> I have installed GEOS 2.2.1 from source and am know trying to install
> postgis 1.1.2.
> postgis is throwing out the following error when I run configure:
> lwgeom_transform.c: In function `pj_transform_nodatum':
> lwgeom_transform.c:545: error: structure has no member named `is_latlong'
> lwgeom_transform.c:564: error: structure has no member named `is_latlong'
> lwgeom_transform.c: In function `transform_point':
> lwgeom_transform.c:973: error: structure has no member named `is_latlong'
> lwgeom_transform.c:974: warning: implicit declaration of function
> `pj_transform'
> lwgeom_transform.c:994: error: structure has no member named `is_latlong'
> make[1]: *** [lwgeom_transform.o] Error 1
> make[1]: Leaving directory `/www/postgis-1.1.2/lwgeom'
> make: *** [liblwgeom] Error 2
> Has anybody got any ideas what is going wrong here and what can be done
> to rectify the problem.
> I'm running on redhat enterprise server 4 with postgresql 7.4
> Any and all ideas will be appreciated.
> Thanks
> Albert
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
