[postgis-devel] Possible server crash detected
strk at refractions.net
Tue Apr 18 05:49:48 PDT 2006
I've fixed the WKT parser to forbid EMPTY elements in multigeometries.
I think it makes sense. Also, if such objects are constructed with
any other mean I added some checks in the code to raise an error
rathern then crashing the backend. Crash tests welcome.
--strk;
On Tue, Apr 18, 2006 at 12:51:33PM +0200, strk at refractions.net wrote:
> Another note: MULTIPOINT(EMPTY) is interpreted as a
> MULTIPOINT with a single, EMPTY element (which is converted
> internally to a COLLECTION, thus making it an invalid
> representation).
> I think you meant to really provide an EMPTY geometry, which
> is obtained by 'MULTIPOINT EMPTY'.
> I think we should first fix the interpretation.
> MULTIPOINT(EMPTY) should probably be the EMPTY geometry,
> whereas MULTIPOINT( ( EMPTY ) ) would be a multipoint
> with an EMPTY element [ possibly, *hopefully* :) unsupported ].
> For a recent discussion about MULTIPOINT WKT format see:
> See: http://lists.jump-project.org/pipermail/jts-devel/2006-April/001572.html
> --strk;
> On Tue, Apr 18, 2006 at 12:15:25PM +0200, strk at refractions.net wrote:
> > I'm taking a look at this bug. Question really is: should we
> > allow EMPTY components in non-collection geometries ?
> > A simpler exploit for the bug is:
> > select summary('MULTIPOINT(EMPTY, 0 0)');
> > --strk;
> > On Mon, Apr 03, 2006 at 04:38:38PM +0200, Markus Schaber wrote:
> > > Hi, Strk,
> > > > Confirmed on 1.1.2 as well.
> > > > Could you file a bug report please ?
> > > http://postgis.refractions.net/bugs/bug.php?op=show&bugid=82&pos=20
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
> /"\ ASCII Ribbon Campaign
> \ / Respect for low technology.
> X Keep e-mail messages readable by any computer system.
> / \ Keep it ASCII.
/ \ Keep it ASCII.
