[postgis-devel] building from source on RHEL ES 3
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Wed Dec 20 01:01:57 PST 2006
On Wed, 2006-12-20 at 09:07 +0100, Tony Grant wrote:
> Hello,
> I am trying to compile on RHEL ES 3 (kept up to date with yum)
> The following error occurs. I have geos-2.1.4-1.i386.rpm (+ devel) and
> proj-4.4.8-4.i386.rpm (+ devel) installed.
> Am I missing another dependency?
> Cheers
> Tony
Hi Tony,
I believe that this has already been fixed in the latest subversion
repository - see
http://postgis.refractions.net/pipermail/postgis-users/2006-November/013885.html for the actual patch, or check the changes against the latest lwgeom_gist.c at http://svn.refractions.net/postgis/trunk/lwgeom/lwgeom_gist.c (not sure if this will work directly with 1.1.6 but you can at least see the latest version).
Kind regards,
Mark.
