[postgis-devel] FW: [Mingw-msys] RE: Bug with backticks behaviour in mSYS?
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue Jan 3 04:51:35 PST 2006
Hi strk/developers,
Happy New Year! :) I've had a response from the MingW people about the
quoting with backticks problem we are seeing which causes PostGIS 1.1.0
builds to fail under Win32. From their point of view, the quoting we are
using is wrong and from the mail below their suggestions would be equivalent
to making the following changes in configure.in:
Line 86/87 change to:
PGFELIBS=-L`${PGCONFIG} --libdir`" -lpq"
PGBELIBS=-L`${PGCONFIG} --libdir`" -lpostgres"
Line 455 change to:
PGFELIBS=`${PGCONFIG} --libdir`"/libpq.dll"
These changes work for me after a quick ./autogen.sh, and allow the build to
complete without error. Does anyone else have any comments/experience about
quoting in this manner, and how it would work on various platforms?
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
> -----Original Message-----
> From: mingw-msys-admin at lists.sourceforge.net [mailto:mingw-msys-
> admin at lists.sourceforge.net] On Behalf Of Keith MARSHALL
> Sent: 03 January 2006 12:15
> To: mingw-msys at lists.sourceforge.net
> Subject: RE: [Mingw-msys] RE: Bug with backticks behaviour in mSYS?
> Mark Cave-Ayland wrote, quoting Luke Dunstan:
> >> The "bash" command you are using is not part of MSYS, so it is
> >> probably Cygwin bash or something.
> > The machine I am using MingW/MSys with is 100% cygwin clean, so it
> > must be something that comes with MingW/MSys/Msys-DTK... I also tried
> > upgrading to the latest candidate of bash from the releases page to
> > see what effect that would also have.
> Mark,
> We don't distribute bash with any standard MinGW/MSYS/msysDTK package;
> (or rather we *do*, but we call it sh.exe, so it runs in its POSIX
> compatibility mode). You *must* have acquired your bash from some
> other source, unless you are referring to the bash-2.05b-MSYS.tar.bz2
> appearing in the MSYS snapshot section of the download page -- and
> you should note that snapshots may not be stable.
> IIRC, this snapshot was provided to kludge any environment variable
> named `prefix' to represent a native Win32 path, even if specified
> with MSYS semantics; this was to co-operate more effectively with
> autoconf, but it has since been established that there is a *much*
> more effective method of achieving the desired goal. In any case,
> that snapshot of bash was intended to be installed as /bin/sh.exe
> Using the standard MSYS sh.exe, from MSYS-1.0.10.exe, and also using
> "correct" portable command quoting, I can't reproduce the failure
> of your original simple test case:
> <file name="test.c">
> #include <stdio.h>
> main()
> printf("this is a test string\n");
> </file>
> <commands>
> gcc -o test test.c
> sh -c 'echo `./test`" -lpd" > x.x'
> od -cb x.x
> </commands>
> <output>
> 0000000 t h i s i s a t e s t s
> 164 150 151 163 040 151 163 040 141 040 164 145 163 164 040 163
> 0000020 t r i n g - l p q \n
> 164 162 151 156 147 040 055 154 160 161 012
> 0000033
> </output>
> (This output is reproduced identically, if I rename sh.exe as bash.exe,
> and adjust the appropriate command accordingly, so even without the
> POSIX compatibility mode turned on, I can't reproduce the failure).
> You should avoid using backtick substitution within quoted command
> arguments; it isn't *generally* a problem with bash, but some shells
> -- notably some of the BSD shells -- mishandle them. And, in this case,
> I *can* identically reproduce your failure when I use improper quoting,
> regardless of whether the shell is called sh.exe or bash.exe, i.e. in:
> <commands>
> sh -c 'echo "`./test` -lpd" > x.x'
> od -cb x.x
> </commands>
> the backticked command is improperly quoted, and fails *exactly* as you
> have described:
> <output>
> 0000020 t r i n g 001 - l p q \n
> 164 162 151 156 147 001 040 055 154 160 161 012
> 0000034
> </output>
> Regards,
> Keith.
> This SF.net email is sponsored by: Splunk Inc. Do you grep through log
> files
> for problems? Stop! Download the new AJAX search engine that makes
> searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
> http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
> Mingw-msys mailing list
> Mingw-msys at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/mingw-msys
