[postgis-devel] FW: [Mingw-msys] RE: Bug with backticks behaviourin mSYS?
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Thu Jan 5 12:27:27 PST 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of strk at refractions.net
> Sent: 05 January 2006 15:02
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] FW: [Mingw-msys] RE: Bug with backticks
> behaviourin mSYS?
(cut)
> Sounds familiar to me, that's probably a good solution.
> I committed a stricter version, for example:
> 	PGFELIBS="-L"`${PGCONFIG} --libdir`" -lpq"
> Could you test on MingW and Solaris ?
> Thanks
> --strk;
Hi strk,
PostGIS 1.1.1CVS now compiles and builds under MingW without any
modifications.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
