[postgis-devel] DBF-Column type boolen and date
strk at refractions.net
Wed Jan 11 07:39:08 PST 2006
[included postgis-devel]
Thanks, here is (one of) the problem(s):
The input has this form:
Date : 20051130
Bool : T
This is safely imported in 'date' and 'bool' fields.
When exported, postgresql returns this:
Date : 2005-11-30
Bool : t
Attached is the output of pgsql2shp (after shp2pgsql).
Does your reader chokes ? Please try multiple readers
if you do have them.
The problem (if it is a problem at all) is that
we use canonical output of every attribute w/out doing
any particular check, when exporting. So if the DBF
format specification expects a specific format for
dates and boolean we'll need to add a post processing
based on type.
--strk;
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060111/a33fda98/attachment.bin>
