[postgis-devel] JDBC: Setting/Getting JTS-geometries using bi nd-vars
Markus Schaber schabi at logix-tt.com
Thu Jan 12 02:49:01 PST 2006
Hi, Aron,
Aron Olsen wrote:
> I did try to use the driver-extension / wrapper, but I couldn't get it to
> work with JTS 1.6 (maybe because the extension was written for a JTS 1.6
> beta release, or maybe it was because our current PostGres/PostGis version
> was too old - I can't remember exactly why).
It would be good to send us the exact problem description if you can
affort to re-try, so I can try to fix it.
> Anyway, I think its better not to be dependent on a certain driver, and that
> is what I believe I have achieved. Can I rely on, that if I use the "plain"
> driver, then I can always get geometries via PGobjects without having to use
> special SQL-syntax ?
What do you mean with "plain" driver? The plain pgjdbc driver without
PostGIS extensions?
No, I'm not shure you can. You know, as soon as the postgis.jar is in
the classpath, newer pgjdbc drivers autoregister the postgis extension,
and this mechanism may change in the future. So your application may
break unexpectedly in future setups.
Second, it is not guaranteed that PostGIS will keep hexewkb as the
canonical rep, at least with major releases the canonical rep is likely
to change (as just happened between 0.X and 1.X).
That's the reason why we use drivers - they can abstract over this changes.
The only reliable way to get a specific geometry representation are the
OpenGIS compliant asText() and asBinary() as well as the PostGIS
specific asEWKT() and asEWKB() functions.
> The nice thing with PGobject / hex-encoded WKB is that you are completely
> independent of a specific Geometry-model (except that one will need to
> re-write XXXParser and XXXWriter for every Geometry-model you want to use).
And the PostGIS Driver just implements three of those geometry models
(PostGIS own, JTS and Java2D).
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in EU! www.ffii.org www.nosoftwarepatents.org
