[postgis-devel] Concurrent Modification and Feature Locking
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Tue Jul 18 02:10:09 PDT 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Cory Horner
> Sent: 17 July 2006 20:53
> To: strk at refractions.net
> Cc: postgis-devel at postgis.refractions.net
> Subject: [postgis-devel] Concurrent Modification and Feature Locking
> Hi Sandro et al,
> We're currently working on eliminating some bugs in the geotools postgis
> plugin, for use in uDig, etc. One problem we've encountered has been
> concurrent modification of features. In geotools we keep a transaction
> alive for some time, as the user tweaks features to their heart's
> content. Unfortunately, when one user modifies a feature and keeps the
> transaction open, a second user attempting to edit the same feature will
> experience a lockup while they wait for the first user to either commit
> or revert.
> What i'm wondering is if there is a way to ask PostGIS (postgres) if a
> feature is locked, or is lockable, so we may toss exceptions or
> otherwise deny modification of a feature when it is not possible?
> Thanks,
> Cory.
Hi Cory,
We can try and help, although we need a more detailed test case to work out
exactly what the issues are. An ideal test case would be a sample .sql file
to load into a blank PostGIS database with some sample geometries, along
with a transcript of example commands typed into 2 simultaneous psql
sessions to replicate the lockup you are seeing.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
