[postgis-devel] loader/ArcZ regression failure
Michael Fuhr
mike at fuhr.org
Wed Jul 26 12:43:30 PDT 2006
I'm getting a regression failure for loader/ArcZ with the latest
code from SVN. I set VERBOSE=1 in run_test and got the following:
loader/ArcZ..... failed (dumping loaded table: /tmp/pgis_reg_59644/dumper.err)
Initializing... ERROR: Cannot determine geometry type (empty table).
If I run shp2pgsql on ArcZ.shp I get this output:
% shp2pgsql ArcZ.shp test
Unknown geometry type: 10
Shapefile type: UnknownShapeType
Postgis type: GEOMETRY[4]
BEGIN;
CREATE TABLE "test" (gid serial PRIMARY KEY);
SELECT AddGeometryColumn('','test','the_geom','-1','GEOMETRY',4);
INSERT INTO "test" (the_geom) VALUES (NULL);
END;
Any ideas?
Michael Fuhr
