[postgis-devel] 1.1.3 release schedule
strk at refractions.net strk at refractions.net
Sun Jun 18 04:33:16 PDT 2006
I'd release 1.1.3 on Friday June 23.
Changes since 1.1.2:
        - Can run the regress tests with 'make check' now.
        - New regress test support for loader/dumper.
        - BUGFIX in pgsql2shp successful return code.
        - BUGFIX in shp2pgsql handling of MultiLine WKT.
        - BUGFIX in affine() failing to update bounding box
        - WKT parser: forbidden construction of multigeometries with
          EMPTY elements (still supported for GEOMETRYCOLLECTION).
        - Added --with-proj-libdir and --with-geos-libdir configure
          switches
        - JDBC:
            - Improved regression tests: MultiPoint and scientific ordinates
            - Fixed some minor bugs in jdbc code
            - Added proper accessor functions for all fields in preparation of
              making those fields private later
        - Support for build Tru64 build
        - Use Jade for generating documentation
        - NEW DumpRings() function
        - BUGFIX in distance(poly,poly) giving wrong results
        - NEW AsHEXEWKB(geom, XDR|NDR) function.
        - Don't link pgsql2shp to more libs then required.
        - Initial support for PostgreSQL 8.2
Anyone with pending issues please report asap.
Thanks.
--strk;
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
