[postgis-devel] loader/dumper tests support
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Mon Jun 19 04:07:16 PDT 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of strk at refractions.net
> Sent: 19 June 2006 11:43
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] loader/dumper tests support
> On Mon, Jun 19, 2006 at 12:28:04PM +0200, strk at refractions.net wrote:
> > I was expecting this while while using -0 ... the best way is probably
> to
> > avoid them IMO, will change the shape.
> Committed with -0s changed to -1s.
> --strk;
Thanks strk.
All regression tests for PostGIS 1.1.3CVS now pass on Win32 :)
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
