[postgis-devel] ERROR: could not load library "/usr/local/pgsql/lib/liblwgeom.so.1.1": /usr/local/lib/libgeos_c.so.1: undefined symbol: _ZN4geos9WKBReader4readERSi
    GIS Nick
    gis at whatevernext.org
    Wed Jun 28 11:10:43 PDT 2006
Hi there,
I have been trying to get postgis working with mapserver.  I
successfully installed postgis, loaded the  sql  scripts  (lwpostgis and
spatial_ref) and successfully loaded a shp file into the database.
However when I subsequently try to access the database through a .map
file I get the following error:
Postgresql reports the error as 'ERROR: could not load library
undefined symbol: _ZN4geos9WKBReader4readERSi '
I found a similar query from this thread here:
"http://postgis.refractions.net/pipermail/postgis-devel/2006-January/001957.html"
which explained that it may be necessary to remove the libgeos.so.2 from
/usr/lib.
I did this and mapserver just gives me a 505 Internal Error.
The result of
ldd /usr/local/pgsql/lib/liblwgeom.so.1.1 /usr/local/lib/libgeos_c.so.1
is:
/usr/local/pgsql/lib/liblwgeom.so.1.1:
        linux-gate.so.1 =>  (0xffffe000)
        libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1 (0xb7e95000)
        libproj.so.0 => /usr/local/lib/libproj.so.0 (0xb7e60000)
        libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7d32000)
        libgeos.so.2 => /usr/lib/libgeos.so.2 (0xb7bf0000)
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb7b09000)
        libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7ae6000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7adb000)
        /lib/ld-linux.so.2 (0x80000000)
        libgeos.so.2 => /usr/lib/libgeos.so.2 (0xb7dd5000)
        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb7cef000)
        libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7ccc000)
        libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7b9e000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7b92000)
in /usr/lib/ I have :
libgeos.so
libgeos.so.2
libgeos.so.2.1.1
in /usr/local/lib I have :
libgeos.so
libgeos.so.2
libgeos.so.2.2.2
What the hell is going on???
You may have gathered that I am a fully-fledged newbie in
postgis/mapserver etc and a (relatively) newbie in Linux.
I would really appreciate any help you can give me here
Thanks,
Nick
