[postgis-devel] estimated_extent & pg_statistic
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Mon Mar 13 06:36:05 PST 2006
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of strk at refractions.net
> Sent: 13 March 2006 10:58
> To: 'PostGIS Development Discussion'
> Subject: Re: [postgis-devel] estimated_extent & pg_statistic
Hi strk,
> I applied your patch with a small modification of #defines in
> postgis.sql.in.
> As you noticed we don't need SECURITY DEFINER for builds against PGSQL
> <800
> so the 'downside' seems to be disapppeared.
> Any test welcome with different pgsql versions and access control layout.
> --strk;
Thanks for reviewing and testing. I'll see if I can find some time to build
something for Martin to test, however I'm currently working flat out on a
project higher up the food chain (application level!) so it may have to wait
a while.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
