[postgis-devel] Adding postgis-config to PostGIS 1.1.2
TECHER David
davidtecher at yahoo.fr
Tue Mar 28 15:16:18 PST 2006
Hi PostGISers,
Happy to send a mail to my favorite mailing-list ;)
I know that my idea is not new but I ask myself, if it could be (before
writing anything...)
Why not using a postgis-config like (geos-config does) for debugging and
maintenance!
I know, i know that for each info I need (example postgis_full_version)
there is a query and a function
(thanks Sandro for the work U do ;) )
But I think that there is a helpfull info which is very interesting is
the information returns at the end of
a 'configure':
cd postgis-1.1.1
./configure
SUMMARY
HOST_OS: linux-gnu
PGSQL: /usr/local/pgsql/bin/pg_config
GEOS: /usr/local/bin/geos-config (with C-API)
PROJ: dir=/usr/local
ICONV: 1
PORTNAME: linux
PREFIX: /usr/local/pgsql
EPREFIX: ${prefix}
DOC: /usr/local/pgsql/doc/contrib
DATA: /usr/local/pgsql/share/contrib
MAN: /usr/local/pgsql/man
BIN: /usr/local/pgsql/bin
EXT: /usr/local/pgsql/lib (\$$libdir)
I think there are interesting information (above) on these summary that
should be helpfull to have on
command like a 'postgis-config' with options for debugging...
For example, on a Debian (or other ..) PGLIB, PGHOME are not the same
directory! (/usr/local/pgsql and /var/lib/postgresql,
or
So why not writting a command that can do
postgis-config --help
Options available:
--version PostGIS version
--configure give you the command line
use by configure to build postgis here,
--configure-summary ( like above)
--prefix you guess, i think
--with-geos 0 is PostGIS was compiled
with Geos or else 0
--with-proj (same idea...)
--help prints these help then exit
Others options?
If U think it could be usefull, please let me know?
But that's only an idea?
--david;
___________________________________________________________________________
Nouveau : téléphonez moins cher avec Yahoo! Messenger ! Découvez les tarifs exceptionnels pour appeler la France et l'international.
Téléchargez sur http://fr.messenger.yahoo.com
