[postgis-devel] postgis-1.1.2: a few improvements
alex bodnaru
alexbodn at 012.net.il
Fri May 19 16:37:47 PDT 2006
hi friends,
i have included the postgis topology functionality in the debian postgis
package, and i'd like to add a few suggestions:
1. for files in topology/test, please apply the attached patches.
it's about a few missed points in the makefile, and with working in
an environment without oids.
2. the topology test fails under postgresql-7.4 wich refuses to have
composite types as fields.
psql:load_topology.sql:214: ERROR: column "feature" has composite type
topology.topogeometry
CONTEXT: PL/pgSQL function "addtopogeometrycolumn" line 91 at execute
statement
it would be possible to save topogeometries as records in a table,
related 1:1 to the one that currently caries the extra column. else,
postgresql 7.4 installations should not receive topology.sql.
3. PGFELIBS, (comming from pg_config --libs) holds all the libs used
when building postgresql. i have substituted $(PGFELIBS) with -lpq (this
exist only in loader/Makefile, for building pgsql2shp), and this seems
to work as well.
the debian packages for postgis are been constantly uploaded to debian
gis, and i hope we'll soon be present in main debian.
best regards,
alex
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060520/4016f9ec/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060520/4016f9ec/attachment-0001.bin>
