[postgis-devel] new DumpRings(geometry)
strk at refractions.net
Mon May 22 04:05:32 PDT 2006
I've committed a new Set-Returning function for extracting
rings from a polygon:
DumpRings(polygon)
Uses the already-available geometry_dump type for return,
which is the same returned by Dump(geometry).
The path element is *always* composed by a single element
in this case, being 0 for the shell and hole number for
each hole.
Making a new type for the specific purpose of this function
would make the soft upgrade procedure fail, so I think it's
better to bear the useless array field then forcing an
hard-upgrade.
Let me know if you disagree :)
--strk;
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
