[postgis-devel] Re: GEOS-3?
Paul Ramsey
pramsey at refractions.net
Fri May 26 07:52:42 PDT 2006
I am finding it very hard to move the archive cleanly while stripping
out the PostGIS side, the result being that I can get GEOS HEAD but
not the branches. svndumpfilter uniformly croaks whenever I try to
filter branches and tags. Very frustrating.
P
On 26-May-06, at 4:35 AM, Mark Cave-Ayland wrote:
>> -----Original Message-----
>> From: strk at refractions.net [mailto:strk at refractions.net]
>> Sent: 25 May 2006 16:03
>> To: Mark Cave-Ayland
>> Cc: 'PostGIS Development Discussion'
>> Subject: Re: [postgis-devel] Re: GEOS-3?
> (cut)
>> What about a postgis-commits mailing list ?
>> --strk;
> It would help, but it doesn't have quite the same functionality -
> ViewVC is
> effectively a web CVS/SVN client so you can browse the repository,
> generate
> release tarballs on the fly, view coloured diffs between any two
> versions....
> Kind regards,
> Mark.
> WebBased Ltd
> 17 Research Way
> Plymouth
> PL6 8BT
> T: +44 (0)1752 797131
> F: +44 (0)1752 791023
> http://www.webbased.co.uk
> http://www.infomapper.com
> http://www.swtc.co.uk
> This email and any attachments are confidential to the intended
> recipient
> and may also be privileged. If you are not the intended recipient
> please
> delete it from your system and notify the sender. You should not
> copy it or
> use it for any purpose nor disclose or distribute its contents to
> any other
> person.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
