[postgis-devel] Loader build under postgresql 8.1.3 fails. Patch for configure.in to solve the issue.
strk at refractions.net
Wed May 31 23:57:25 PDT 2006
Granted, I never felt comfortable with that.
Committed. --strk;
On Wed, May 31, 2006 at 11:09:32AM -0400, Stephen Frost wrote:
> Greetings,
> The loader build is fine without the additional --libs. Indeed,
> adding the extra libs can cause serious problems if, for example, the
> .so's the server is compiled with is different from the .so's the
> PostGIS module is compiled with. This results in two different
> versions of the same library being linked into the running PostgreSQL
> process with conflicting symbols. This can cause PostgreSQL to crash.
> For the actual loader, they don't need the extra .so's to even be
> available to compile normally, just libpq (shp2pgsql doesn't even need
> that, actually!).
> Please revert the configure.in patch.
> Thanks!
> Stephen
