[postgis-devel] PostgreSQL 8.2devel now requires PG_MODULE_MAGIC
strk at refractions.net strk at refractions.net
Wed May 31 23:59:16 PDT 2006
I added it to lwgeom_pg.c.
Please give it a try.
Thanks.
--strk;
On Wed, May 31, 2006 at 08:27:38PM -0600, Michael Fuhr wrote:
> The PostgreSQL development branch (8.2devel) now requires shared
> libraries to have a magic block.  Without the magic block, functions
> in shared libraries fail thusly:
> postgis=> SELECT postgis_full_version();
> ERROR:  incompatible library "/usr/local/pgsql82/lib/liblwgeom.so.1.1": missing magic block
> HINT:  Extension libraries are now required to use the PG_MODULE_MAGIC macro.
> CONTEXT:  SQL statement "SELECT  postgis_lib_version()"
> PL/pgSQL function "postgis_full_version" line 11 at select into variables
> Here are some relevant messages and the documentation:
> http://archives.postgresql.org/pgsql-patches/2006-05/msg00106.php
> http://archives.postgresql.org/pgsql-committers/2006-05/msg00382.php
> http://archives.postgresql.org/pgsql-committers/2006-05/msg00394.php
> http://developer.postgresql.org/docs/postgres/xfunc-c.html#AEN33753
> According to the documentation, an extension module's source code
> should have the following somewhere:
> #ifdef PG_MODULE_MAGIC
> PG_MODULE_MAGIC;
> #endif
> Michael Fuhr
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
