[postgis-devel] Bad proj4text strings in spatial_ref_sys?
Michael Fuhr
mike at fuhr.org
Sat Nov 4 11:14:09 PST 2006
I wrote a function to look for unusable SRIDs and it found 29 in
the latest spatial_ref_sys. Below are the function and output --
am I doing something wrong or are these proj4text strings incorrect
because they're missing a +proj= parameter?
CREATE FUNCTION srid_test(OUT bad_srid integer, OUT error text)
RETURNS SETOF record
AS $$
DECLARE
geom geometry := GeomFromEWKT('SRID=4326;POINT(-100 40)');
rec record;
BEGIN
FOR rec IN SELECT srid FROM spatial_ref_sys LOOP
BEGIN
PERFORM transform(geom, rec.srid);
EXCEPTION
WHEN others THEN
bad_srid := rec.srid;
error := SQLERRM;
RETURN NEXT;
END;
END LOOP;
END;
$$ LANGUAGE plpgsql STABLE;
SELECT * FROM srid_test() ORDER BY bad_srid;
bad_srid | error
2046 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2047 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2048 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2049 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2050 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2051 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2052 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2053 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2054 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
2055 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs ': projection not named
22275 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22277 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22279 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22281 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22283 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22285 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22287 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22289 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22291 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22293 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.145 +b=6356514.966398753 +units=m +no_defs ': projection not named
22300 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+a=6378249.2 +b=6356515 +pm=paris +units=km +no_defs ': projection not named
29371 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
29373 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
29375 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
29377 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
29379 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
29381 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
29383 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
29385 | AddToPROJ4SRSCache: couldn't parse proj4 string: '+ellps=bess_nam +to_meter=1.0000135965 +no_defs ': projection not named
(29 rows)
Michael Fuhr
