[postgis-devel] Win32 crashes with PostGIS 1.1.4 / PostgreSQL 8.2 -- solved
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Wed Oct 11 05:53:14 PDT 2006
On Wed, 2006-10-11 at 12:51 +0200, Markus Schaber wrote:
> Hi, Mark,
> Mark Cave-Ayland wrote:
> > One other quick thought: since the soon-to-be-released Win32 installers
> > now create a "template_postgis" database by default, would it worth
> > making a note in the documentation that if your installer has created a
> > template_postgis database then you can can create a GIS-enabled database
> > with simply: createdb -T template_postgis
> I think that's a good idea.
> Can you submit a doc patch?
> Thanks,
> Markus
Hi Markus,
Here she is. Unfortunately I don't have a documentation build
environment setup on either MingW or Linux, so if someone could check it
that would be great.
Kind regards,
Mark.
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20061011/c2c10692/attachment.bin>
