[postgis-devel] Win32 crashes with PostGIS 1.1.4 / PostgreSQL	8.2	-- solved
    strk at refractions.net
    Wed Oct 11 08:17:03 PDT 2006
On Wed, Oct 11, 2006 at 12:50:58PM +0200, Markus Schaber wrote:
> > Should we remove the .pdf from repository then ?
> Is there any command line way of producing pdf or html from an .odt
> file? I don't like to put the burden of installing OpenOffice.org just
> to view the docs.
Argh... any chance that OpenOffice is able to export in docbook ?
(strk's deaming)
> Can a regression test check for an expected failure? I'd want to make
> shure that it properly rejects files that contain true Multi-Geometries.
mm.. no support for that currently, but we might think about it.
--strk;
