[postgis-devel] Re: PostGIS datastore creation
Greg Troxel gdt at ir.bbn.com
Tue Sep 19 17:13:09 PDT 2006
  - The workaround to this would be to have a standard spatially-enabled
  TEMPLATE available in the server install, a "template_gis", if you
  will.
To make binary packages easier, please instead install a script that
when run creates the template.  The build machine and the run machine
may well be different (and in a future ideal world even cross
compilation would be supported).  Such a script could be hooked into
the pkg install process if desired.
(I've created a binary package in pkgsrc for postgis built against
postgresql81.)
    Greg Troxel <gdt at ir.bbn.com>
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20060919/d33328f5/attachment.sig>
