[postgis-devel] Re: PostGIS datastore creation
Mateusz Loskot mateusz at loskot.net
Thu Sep 21 12:41:52 PDT 2006
Paul Ramsey wrote:
> Mateusz,
> Go ahead with the assumption that you can just issue a "CREATE DATABASE
> <dbname> WITH TEMPLATE = 'template_postgis' "  and we'll work on making
> sure that template_postgis exists at the server side...
Paul,
IMO, it's a reasonable solution. I'll follow it.
>  You might want
> to check the existence of the template as part of seeing if you'll
> advertise this capability to clients.
Yes, good idea.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
