[postgis-devel] Re: [Bizgres-general] Bizgres MPP and PostGIS
Markus Schaber schabi at logix-tt.com
Mon Sep 25 13:36:35 PDT 2006
Hi, Luke,
Luke Lonergan wrote:
> I understand that we've added an API extension to the "CREATE AGGREGATE"
> statement.  Normally it takes two arguments, now it takes three, the third
> being there to act as an accumulator (Brian, Alon, perhaps you can
> elaborate).
Ah, that clears it up, thanks.
So the 9 aggregates defined by PostGIS would need to be extended by an
accumulator. Should be a straight-forward task, AFAICS.
> With our upcoming (early November) release, I understand that we support the
> UDFs (including those written in "C"), custom types and parallel aggregation
> needed by PostGIS.  The one exception we can think of is that we still don't
> support TRIGGERs.  Does PostGIS still need them?
AFAICS, PostGIS needs triggers for "long time transaction support"
(which I never looked at closely). There's an cache_bbox trigger
function one can explicitly add to control bbox caching handling, too.
There are also CHECK constraints to enforce consistency for OpenGIS
compliant tables, but well-behaving applications (or those deliberately
not relying on OpenGIS compliance by creating mixed-type columns) can do
without them.
So, I'd say, PostGIS core functionality is available without triggers,
but some extended functionality needs it.
HTH,
Markus
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in Europe! www.ffii.org
www.nosoftwarepatents.org
