[postgis-devel] postgis_proc_upgrade.pl dropping aggregates
Obe, Regina robe.dnd at cityofboston.gov
Wed Aug 22 07:50:07 PDT 2007
Nope didn't show up at all to my recollection and actually everything
else upgraded nicely except for the aggregate functions as far as I can
tell.  e.g. I got the new st_dwithin and st_within, st_coveredby etc
functions.  After upgrade didn't say I needed to upgrade procs.
I don't think going from 1.2.1 to 1.3.1 is considered a major upgrade or
is it?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, August 22, 2007 9:12 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] postgis_proc_upgrade.pl dropping aggregates
On Wed, 2007-08-22 at 08:55 -0400, Obe, Regina wrote:
> This is actually a continuation of the thread on Postgis users about
> Collect vs. ST_Collect GeomUnion vs ST_GeomUnion, but thought it would
> be better dealt with in this group.
> Looking at the
> http://svn.refractions.net/postgis/trunk/utils/postgis_proc_upgrade.pl
> Commented out section on aggregate functions.  I see we are doing a
> DROP AGGREGATE $aggname($basetype);\n
> I was going to change to do
> DROP AGGREGATE IF EXISTS $aggname($basetype);\n
> But I'm not quite sure when IF EXISTS was introduced into Postgresql.
> Does anyone have an idea when that was introduced and if we did change
> the above to something like that if it would pose problems elsewhere.
> I guess we would still have the problem if someone is using the
> aggregate functions in a view or something like that it would fail a
> drop.  Haven't quite figured out a workaround for that so its still
not
> as nice as a CREATE OR REPLACE would be.
> Thanks,
> Regina
Actually thinking about this more: I don't think the scripts upgrade can
work across a major version upgrade because the upgrade script cannot
know the old version of PostGIS, and hence which functions need to be
removed from the existing database :(
In fact, towards the bottom I see this:
	IF old_maj != new_maj THEN
		RAISE EXCEPTION ''Scripts upgrade from version % to
version % requires a dump/reload. See postgis manual for instructions'',
old_scripts, new_scripts;
	ELSE
		RETURN ''Scripts versions checked for upgrade: ok'';
	END IF;
Did this exception not show up during your upgrade at all?
<thinks harder>
Perhaps a better idea would be to work on
http://svn.refractions.net/postgis/trunk/utils/create_undef.pl again so
that it parses the lwpostgis.sql file at build time to create a .sql
file that removes all of the PostGIS functions/types/operators for the
current version.
We could then build this into the database as a function that returns
the text of the resulting undef SQL file as text, e.g. so SELECT
postgis_uninstall_script() returns a single text field containing the
contents of this file.
Then if we need to upgrade at all, the upgrade client can just do SELECT
postgis_uninstall_script(), and then execute the resulting text on the
server to uninstall the old version; then aferwards it can execute the
new scripts to load in the new functions.
</thinks harder>
Thoughts?
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
