[postgis-devel] 3d in postgis
Mathieu Le Serre
mathieu.leserre at camptocamp.com
Fri Dec 21 08:19:45 PST 2007
Hi all,
A few months ago, I wrote some patchs related to 3D geometries storage
in postgis. (See for instance http://tinyurl.com/3y9xhv)
Since september, I've been working on several import/export functions,
based on TIN and POLYHEDRALSURFACE, which are geometries that describe
3D volumes or surfaces.
I first developed a script named collada2pgsql which imports TIN or
POLYHEDRALSURFACE from collada format. It allows importing and storing
geometries with texture informations.
I also wrote two export functions:
-pgsql2kmz: which exports pgsql geometries into kml or collada
format, and allows to see the model in GoogleEarth. It is possible to
export a textured model if the informations are stored in PostGIS.
-pgsql2x3d: which exports pgsql geometries into x3d format. It is
also possible to export with textures
All the information you need to use these functionalities are available
from this url: http://postgis3d.blogspot.com
HTH,
Mathieu
