[postgis-devel] Warnings compiling PostGIS 1.2.1 with GEOS 3 RC4
strk at refractions.net
Fri Feb 9 06:26:03 PST 2007
On Fri, Feb 09, 2007 at 02:13:43PM +0000, Mark Cave-Ayland wrote:
> On Thu, 2007-02-08 at 23:39 +0100, strk at refractions.net wrote:
> > On Thu, Feb 08, 2007 at 09:46:22PM +0000, Mark Cave-Ayland wrote:
> > > lwgeom_geos_c.c:2439: warning: assignment discards qualifiers from
> > > pointer target type
> > PostGIS is currently using the compatibility definition left
> > in geos_c.h. Using the new ones is likely possible but will
> > take some attention for builds against older GEOS.
> Okay - so am I right in understanding that the warnings are not
> dangerous, but could be fixed if someone spent time working on
> lwgeom_geos_c.c? FWIW all PostGIS and GEOS XMLTester regression tests
> pass.
Yes.
--strk;
